GILERA TYPHOON ZIP SPARES CHEAP.
Discussion in 'For Sale' started by rideorcollide, Jul 27, 2009.
  1. rideorcollide
    rideorcollide Active Member
    TYPH 172
    got loads of parts sitting around, need to make space
    gilera 125 series 2 gearbox (not rolling nut) £10
    125 clutch bell £5
    125 gilera engine casing with no shaft or spring. ?
    typhoon back wheel (mini nrg one) punctured tyre.small drum type. ?
    zip 80cc engine, needs a stator. with loom pipe and carb. £50
    zip sp forks with front wheel, bars and caliper, fresh trye £40
    typhoon 50 forks with front wheel, bars and caliper (scored disc) £30
    typhoon 50 front calipers. ?
    typhoon 50 engine (has everything exept top end and the crank threads are a bit fucked.. comes with a fresh back wheel.) £30
    typhoon back panels, 1 side is missing lugs. 2 typh belly panels, 1 has no lugs 1 has a crack.
    typhoon 50 petrol and oil tanks. ???
    gilera runner 125 rear caliper. £20
    typhoon rear shocks x2 ??
    probably more aswell i cant remember, ask if you need anything.. i kinda want it all gone, the things with a question mark can be had for free if you pick them up..
    prices are there for everyhting else, or make offers..
    i can post, and i accept paypal :good:
  2. rideorcollide
    TYPH 172
    Re: random cheap gilera zip typhoon spares..parts..engines
    o yeah and a stage6 torque control clutch £20
    typh 50 variators
    gilera 125 magneto
  3. monty9120
    monty9120 Active Member
    Vespa gts300
    black front runner caliper?
  4. rideorcollide
    TYPH 172
    nah only back
  5. LEE
    LEE Member
    i got front black
  6. monty9120
    Vespa gts300
    i need 2 bolts. :pale:
  7. LEE
    LEE Member
    as well as caliper or you meen you need just the 2 bolts
  8. rideorcollide
    TYPH 172
    monty make youre own topic 2 sell your caliper or pm or suttin man..
    update..i got a 21mm carb for sale aswell with manual choke.. off a nrg
    £30 posted
    SOLD
  9. monty9120
    Vespa gts300
    just need the 2 bolts from the back of the caliper the ones that hold the pads in
    rideorcollide, chill your beans i cant help it if you cant satisfy my needs :mrgreen: :cheers: :grin: :lol: :yahoo:
  10. rideorcollide
    TYPH 172
    Re: random cheap gilera zip typhoon spares...engines.. 21mm carb
    no...but you can pm lee abut your caliper
  11. connor
    connor Active Member
    will the 80 bore an piston fit on a ice? if yeah how much you want for the 80kit?
  12. rideorcollide
    TYPH 172
    it will fit but the conrod on the 50 engine is too short so u gotta fit the 80 crank aswell
