gilera stalker parmakit 70 fitted , need help with jetting
Discussion in 'The Workshop' started by chris taylor, Sep 15, 2012.
  1. chris taylor
    chris taylor New Member
    gillera stalker
    hi ive just fitted a parmakit 70 to my stalker i have pipe rollers and clutch set up but im finding jetting an issue , im running a tnt filter i have a 110 main in at the mo it starts ticks over and pulls away fine but bogs if i pull the throttle right open , should i go bigger on the main ????????
  2. gilly_runner
    gilly_runner Member
    Gilera runner
    What parmakit 70 kit do you have ? and what tnt filter ? the odds are you will need to fit a bigger jet i have seen people running anything up to a 135 jet in a 17.5mm with open airfilter...
    always remember its best to start of big then go down to stop it from running lean and causing damage to the engine
  3. Thatcharliebre
    Thatcharliebre Member
    135??? My 19mm with open airfilter pm360 and 70 kit has an 88 jet in. Mechanic put it in
