Gilera stalker drag
Discussion in 'Newbie Scooter Tuning' started by tinnion-stalker, Nov 16, 2010.
  1. tinnion-stalker
    tinnion-stalker New Member
    Hello this is my first post i have a 2000 gilera stalker when i get to about 20mph and i can feel it draging it feels like the back brake but i no its not that as i took it off and still the same its more like a on off drag sort of thing if u need any more info just ask me thanks.
    P.S can some1 tell me why petrol is going into my airbox thanks.
  2. ramo
    ramo GoldMember
    what rollers are you using? those would be the first thing i would check for the 'dragging' problem
  3. tinnion-stalker
    hello it has original rollers in you can feel it like every 3-5 seconds when your moving you feel the back end drag thats the only way i can put it.
  4. northrider
    northrider Member
    have you opened up to check the variater possible they could be worn and out and no longer rounded this is just a possibility im not sure
  5. ramo
    ramo GoldMember
    i would give the whole transmission the once over....variator/rollers, gears/oil clutch everything. your problem is most likely gonna be something to do with the transmission
  6. tinnion-stalker
    it has a new clutch,rollers,belt and new transmission oil.
