Whats the best thing i can improve my gilera runner vx 51 plate acceleration? variotor, rollers etc.?
Re: Gilera Runner i was thinking to get a multivar 2000 or polinis variator but dont know if it really improves acceleration that much, so i dont wanna waste 100 pounds on something that doesnt even do nothing
Re: Gilera Runner Not worked with runners so wasn't sure. My bad. Not too sure all you can really do is pipe/200kit/variator.
Re: Gilera Runner If it's a 125 vx then nothing really. 4 Strokes don't tune well. You have to spend huge amounts to get gains. Much easier is to either buy a bigger engined bike or transplant a larger engine in. They are near impossible to find however.
malossi 210 bore kit would just about give it more power and an exhaust but these alone would cost over £500 and your not getting much so its not worth it tbh
Re: Gilera Runner Can anyone answer this pleaes? does it realy make a diffrence? If so can you achieve the same result by changing the roller weights in the original? or is there some 'super duper' engineering factor that the polini has? thanks... (I'm a newbie to the forum) :thumbsup:
Simple fact is with 4 strokes if you want more power either spend a huge amount of buy a larger cc bike. There is no such thing as as small amount of money for gains on a 4 stroke.
Just seen the topic pal. I had a vx125 for about 3 years, i bought the malossi multivar and the pm61 pipe, with malossi kevlar belts. The variator improved acceleration with lighter rollers i used between 9 and 12 gram rollers u will have to experiment their 19x17 and the cheapest place to get them is beedspeed. The pm61 pipe was expensive at 280 odd quid but it looks mint and it also improved acceleration plus im still using it now on my 200. The 210s are not worth buying on there own (never tried but been told) because they dont last unless u spend hundreds and hundreds on everything else like powercams.
