gilera runner forks and front wheel problem...
Discussion in 'The Workshop' started by Junior95, May 9, 2011.
  1. Junior95
    Junior95 New Member
    My handle bars are not in line with the front wheel and forks i think the front wheel may be buckled but i dont know what to do or where to start as i dont know alot about fixing bikes :cry: :cry:
  2. m1ck_t
    m1ck_t Moderator Staff Member
    alot of shit
    Re: gilera runner 180 helpp
    Remove the panels surrounding the handle bars , undo the bolt that clamps the bars to he forks and move the handle bars into position , then re tighten the bolt and assemble the panels back on . This is of course assuming your handle bars and forks are all true .
    Regarding the front wheel . put the bike on centre stand and place something under the belly pan to keep the front wheel of the ground , spin the wheel and look at the side of it (from the front) to check for run out. If you place something like a flat screwdriver against a fork leg Pointing to the rim wall (keeping it about 2mm) from the rim , spin the wheel and the distance between the tip of your tool and the rim should not change. do this to both sides of the rim .
    And please title your topic accordingly
  3. Junior95
    Junior95 New Member
    thanks for the help
  4. RIGZ.172
    RIGZ.172 Member
    camel
    m1ck_t well said :)
