Gilera Runner 70cc
Discussion in 'Scooter Tuning' started by Matic1234, Mar 27, 2018.
  1. Matic1234
    Matic1234 Member
    I want to buy a Gilera Runner SP, but almost every Runner has more than 15k km. Is 15k too much if I want to put a 70cc sport kit (DR EVO, Stage 6 Streetrace,...) on my bike?
  2. Sam phantom
    Sam phantom Active Member
    No not really. if it’s been run on good 2stroke oil
    I’m in the middle of doing a midrace 70 on a runner with 22000 miles on the clock when I took it apart the old barrel and piston looked fine
  3. Matic1234
    Matic1234 Member
    Is the crankshaft still good for a 70cc?
  4. Sam phantom
    If you don’t push it too hard yes, depends on what 70cc kit it is though
  5. Sam phantom
    Mine is midrace kit so the old crank Won’t be strong enough
  6. Matic1234
    Matic1234 Member
    How much does a good crank for a 70cc sport kit cost? Will I be able to replace it myself?
  7. Sam phantom
    I Haven’t got a clue! my crank was £140
  8. Stevep
    Most of the standard cranks will be ok with a mid-race 70 kit, as Sam said above, it depends on how it's been treated in the past.
    With the top end off you can check the play in the conrod sideways movement, if it's too excessive then replace it before you fit the new kit.
