Gilera runner 183
Discussion in 'Maxiscooter Tuning' started by Cuki_88, Nov 11, 2011.
  1. Cuki_88
    Cuki_88 New Member
    Ive had my engine cases flowed and the head ported. Im planning on putting a 55mm long stroke crank in aswell. My question is because the bore hes been ported the walls are alot thinner so do i have to cut the gasket down to match the bore. Just to stop the gasket blocking the ports that have been widend. Also do i install a base plate for the 55mm crank say a 3mm base plate ?? Any advice would be appreciated.
  2. 125TypHXR
    125TypHXR Member
    hae u had the barrel ported for the 55mm ?
  3. 125TypHXR
    125TypHXR Member
    theres like 100 other post's on here about this why not just use the search
  4. Cuki_88
    Cuki_88 New Member
    Im not sure what its been ported for just know its been ported. Also i havent searched because id be looking for hours the amount of forums that are on here. Easier just to ask and then get the answer.
  5. xplicit vehicle
    xplicit vehicle Member
    PGO Big Max 50
    they really should make this a sticky then
