Gilera runner 180 with 172 pro street kit no acceleration
Discussion in 'Maxiscooter Tuning' started by G4VOE, Feb 18, 2023.
  1. G4VOE
    G4VOE New Member
    I have a 2002 gilera runner 180 with a pro street 2 kit
    brand new 180 belt
    Malossi clutch red springs white contra
    25mm carb
    Mhr inlet
    Brand new 12.5g rollers
    Malossi cdi
    Pm59
    the bike has no acceleration at all almost struggles then at about 20mph it unexpectedly kicks in nearly throwing you off
    cant think what else to try played about with clutchs and contra springs
  2. MARSH
    Put the complete std clutch back in it !
  3. G4VOE
    G4VOE New Member
    Thanks marsh, i currently have to complete standard clutch in it and still the same?
  4. G4VOE
    G4VOE New Member
    Also its standard 125 variator with metal metal on it but i have just got a malossi variator
  5. Stevep
    Have you re-jetted the carb to the suit the PM pipe?
    And why has it got the 172 kit on it if it's a 180??
  6. Stevep
    Also standard airbox or pod filter?
  7. G4VOE
    G4VOE New Member
    Im running a 102 main jet and 50 pilot jet doesnt seem to bog or splutter at all, i fitted the 172 kit as i believe there better for when tuning bikes due to ports and that? I could be wrong but its running alot better as a 172 than it did as a 180
  8. MARSH
    The drive belts are different for 125 , 180cc so use the right one !
  9. G4VOE
    G4VOE New Member
    I brought the belt as a 180 belt from the shop is there a way to tell by part number or anything? It does kinda sound like belt slip or clutch slip as it doesnt struggle to rev just to pull off
  10. MARSH
    Check on "Fowlers of Bristol" web site for part numbers.
