Gilera Runner 172 clutch set up.
Discussion in 'Maxiscooter Tuning' started by hmsp125, Jan 22, 2008.
  1. hmsp125
    hmsp125 New Member
    Basically i've got a malossi delta clutch an i have brought the 3 set malossi clutch spring set, This set consists of three different types ( Blue ) soft ( green ) medium and ( red ) hard. i have heard a few people using the blue one's however they are such a bugger to fit. i was considering putting the clutch in the freezer for a hour to two so it reduces the size and makes the spring's easier to fit?? Any advise would be very much appreciated :beer:
  2. james
    james Member
    Put blue springs in the standard clutch the malossi clutches aint any better than the standard its just the name they do the same thing!
  3. hmsp125
    hmsp125 New Member
    How would i go about fitting them though?? As i've tryed it with needle nose pilers but dont seem to do the job.. Thats why i was considering freezing the clutch fo a hour or so.
    Cheers
  4. Nrg-Sam
    Nrg-Sam Active Member
    get a hacksaw, cut a notch into a flat headed screwdriver so its like this
    __ ___
    fit one end of the spring right, then get the other end in the notch, put one foot on the clutch, now push down so you stretch the spring into position, get another flat headed screwdriver and lever the spring end into place
    once youve got the hang of it, its a 3 minute job :cool:
  5. Daniel172
    Daniel172 Member
    Piss easy to fit springs on a 50 clutch but 125's are a different story lol just a little bit stronger..
  6. Dec
    Dec Active Member
    nothing ugm
    i think thats the most useful thing iive heard all week, cheers sam :beer:
  7. Dec
    Dec Active Member
    nothing ugm
    just re-read my post it come out quite sarcastic but it wasnt mate ;)
  8. MiNoR cOnFuSiOn
    blue springs dontr just go into a 125 clutch.. you need to wiggle them in place.. neer impossible with the clutch assembled and fuck all goomd trying to lever them with a screwy.. you will end up with the screwdriver in you
  9. alexsr70
    alexsr70 New Member
    i thought the malossi delta was adjustable??
    well someone on here said that to me i think.......
  10. liamspeedy
    liamspeedy New Member
    its much easyer to fit them by taking the cluch apart.
  11. Anonymous
    Anonymous Guest
    ive so done that to many times :w00t:
