Gilera runner 172 28mm carb help
Discussion in 'Maxiscooter Tuning' started by LIVELY16, May 28, 2008.
  1. LIVELY16
    LIVELY16 New Member
    ive just finished putting my engine back in my bike with brand new 172 kit , when i started it and ran it for a couple of minits it idle quite high, what could be the porblem , im guessing i need to raise the clip a knotch because when i fiddle around with the idle mix it did not do anything , unless ive got a hole in the rubber manifold which could be the problem 2 couldnt it . ps the carb is 28mm. cheers.
  2. kyle1b1
    maybe try idle speed ??
    are you sure your qualified to have a highly tuned motor ? :rofl:
  3. LIVELY16
    LIVELY16 New Member
    and are u quilifed to read :pimp: , i said i played with the idle screw and said it did not make no diffrence . and yes i no im an idiot i did not check the manifold for cracks . and what is a good notch to start with on the needle .
  4. kyle1b1
    you sad idle mix not idle speed :bird:
    middle notch is a good place to start i would have though
    but doubt the needle postition would make it idle very high
  5. LIVELY16
    LIVELY16 New Member
    ite cheers mate .
