gilera runner 125 engien whineing
Discussion in 'The Workshop' started by jj180, May 23, 2008.
  1. jj180
    jj180 Active Member
    Mrt 183/Vespa 300
    bascially my engine has got a slight whine from the magneto side of the engine when giveing it a lil dab of throttle jsut over idle, also happens when slowing down to a set of light etc just before the engine idles.... suggestions please and many thanks in advance
    sorry jsut to add if you dotn know i have a 172 runner,
  2. kyle1b1
    mine has started doing this latly sounds like from around the cylinder :msn1:
    not had a decent look though.
    only started since i i tightened the exhaust.
    so maybe passed the vibrations else where
  3. jj180
    jj180 Active Member
    Mrt 183/Vespa 300
    was thinkin that today i tightened my exhaust onto the bracket and thats all ive done so could be that
  4. kyle1b1
    extactly what i did tightened the exhaust to the bracket.
    what is vibrating then J ?
    i cba to look :rofl:
  5. jj180
    jj180 Active Member
    Mrt 183/Vespa 300
    its a low level wine foookin annoyin
  6. kyle1b1
    yeh it fooking is.
    like you said is whn you let off throttle then starts.
    but sometimes mine goes away.
  7. jj180
    jj180 Active Member
    Mrt 183/Vespa 300
    urs is def the exhaust if its whens ur off the trottle mines is onli when i throttle at idle
  8. jj180
    jj180 Active Member
    Mrt 183/Vespa 300
    bump still whineing
  9. one7twoboi
    one7twoboi New Member
    have your checked stator and flywheel? if not it aint gonna take 5 mins to whip the tranny off and have a peek, might be worth while mate, my runner done the same thing and and weeks later the bloody variator stripped the splines off my crank :(
  10. jj180
    jj180 Active Member
    Mrt 183/Vespa 300
    changed everthing as used to have the problem of my variator rubbing on the gold casing inside the transmission, and changed the magneto since and still wining
  11. numanoid1704
    numanoid1704 New Member
    water pump
    water pump bearing?
  12. MiNoR cOnFuSiOn
    Re: water pump
    what have we got for him jonnie?
    (id put my money on that also)
  13. jj180
    jj180 Active Member
    Mrt 183/Vespa 300
    fair point sounds about right when i think about it, fancy doign a rebuild anyone ??? asap
