Gilera rear wheel bearing
Discussion in 'The Workshop' started by hollowpoint71, Sep 20, 2017.
  1. hollowpoint71
    hollowpoint71 New Member
    Hi can anyone point me in the right direction for a new rear wheel bearing that is in the exhaust bracket of a gilera 125 vx runner,thanks in advance.
  2. Mark Emerson Trentham
    Pulled up 1 company on E/bay:-
    MTLF Bearings (Athena) - might need brush up on your Italian.:).
  3. scubabiker
    Try and measure the dimensions of it
  4. Renllek
    Renllek Member
    if you have the bearing out then 'most' bearings have the size code on the side of the outer race
  5. Stevep
    Knock it out the housing, measure the inside (hole), measure the outside diameter, measure the thickness, go to simply bearings.co.uk,
    put the sizes in the boxes on the top of the page, PRESTO!
    You need a sealed bearing, not an open one.
    OR
    Knock the bearing out the housing, clean it, use a magnifying glass to read the numbers on it, e.g. 6204zz, and use simply bearings to get a new one.
    Just done a quick search. This should be the one; 17 x 47 x 14
    But check your sizes first.
    Here you go:
    https://simplybearings.co.uk/shop/advanced_search_result.php?keywords1=17&keywords2=47&keywords3=14
  6. hollowpoint71
    Thank you so much for all your answers.
