Gilera 180/172 how many fuses are here on a gilera runner?
Discussion in 'The Workshop' started by Gilera172BadBoy, Nov 28, 2010.
  1. Gilera172BadBoy
    Gilera172BadBoy New Member
    172 Gilera Runner
    How many fuses are there becuase i am going to replace them all as im not sure if they are all working..
    could a fuse stop ur electric start working?
  2. capri dave
    capri dave Active Member
    Re: Gilera 180/172 how many fuses are here on a gilera runne
    theres 5 fuses in total 1x 25 amp, 2x 10 amp and 2x 7.5 amp.
  3. Gilera172BadBoy
    172 Gilera Runner
    could these stop your electric start from working?
    and do you know what there all for?
  4. Surferdude
    Surferdude Member
    Area 51 50cc w/c
    I posted a question bout the same a few days ago! Lol
    Battery flat mate? Will the scoot start with the kick start? Or the starter relay knackerd?
  5. jamesknowles1991
    jamesknowles1991 New Member
    gilrea runner 125 sp
    best thing to do is to check ur battery is in not flat is it makeing a ticking sound as the starter wheel could be sezied tell use what is acutly going on and to check the fuse see if any of them have a black spot i the middle
  6. Gilera172BadBoy
    172 Gilera Runner
    nah got a new battery, and i have now got all new fuses changed all 5 well gettin them tomz.. and im not sure what it can beo_O
  7. jamesknowles1991
    is it making a click sound when u press the elec start??
  8. Gilera172BadBoy
    172 Gilera Runner
    nahh no noise
  9. jamesknowles1991
    no noise
    right have you checked the fuses them self ?? any black spot in the middle ??
  10. Gilera172BadBoy
    172 Gilera Runner
    my mate dad got me all new ones.. i took all 5 out that i know of.. and im gona be puttin them back in maybe tomz if i get them..
    if not them what could it be?
  11. jamesknowles1991
    if the fuses are clean not black mark inside there fine
    so is the battry charged??
    also try spraying all connection wid wd40 helps get rid of shit around them
  12. Gilera172BadBoy
    172 Gilera Runner
    okk i dont know till i get em back just puttin new ones in..
    and yh got a brand new one fully charged..
    and the connections going to were?
  13. jamesknowles1991
    every where mate the elec starter relay is on the right side half way up the back tailthats should click if somethin is right but all seem conected so
    what i need you to do is take the starter motor off its located underneth nnot far from the stand if you dont know what one look like its similer to a oil filter on a car if you dont know wat one of the is ill post a pic just incase anyways the way i found out if mine wok was to take that off and twist with your hand if it moves its ok if not its seized and need a new one but if it does spin try placeinf the corner on you fram and see if it spin do all that and get back to me because i think your starter motor seized like mine did but if you can kick off then the electric arnt fulty as much.
    when you take off the starter motor the lead will show you where the relay is anways :)
    as for the wd40 i was told by a mechanic to do it so dont think im want to cock up ur gilrea cuz i dont mate
  14. jamesknowles1991
