getting the magneto out of L/H side crankcase
Discussion in 'The Workshop' started by looxor-lad, May 14, 2009.
  1. looxor-lad
    looxor-lad New Member
    pug looxor 02
    how would i get the capacitor out as when i turn the nut to undo it it just spins compresing the piston etc. i need to get this out to replace the crank case? any ideas?
  2. PrettyDodgyDave
    PrettyDodgyDave Member
    Runner 180
    Re: getting the capacitor thing off l/h side crank case
    air gun the nut off then need a flywheel puller to pull of the magneto :up:
    can be done without or so im told never done it without a puller :up:
  3. MiNoR cOnFuSiOn
    capacitor? left side?
    replace crankcase? does this make sence to anyone? :msn1:
  4. looxor-lad
    pug looxor 02
    ahh sorry didnt make it very clear n the pug the magneto i behind the fan on the left hand side of the engine. i need to take this of to replace the engine casing aso mine snapped the exhaust mount that was on it. so i need to take the magneto etc out to put the new casing on then rebuild it.
    sorry didnt make it too clear
  5. MiNoR cOnFuSiOn
    thats the right side... and you replace them as a pair not singally... your engines fucked
  6. looxor-lad
    pug looxor 02
    cheers for that mate atleast i got both sides then i thought id get away with just the one side was wondering why the fella gave me them both
  7. MiNoR cOnFuSiOn
    but ye, use an impact wrench. then a flywheel removal tool... seems a bit of a pain to buy 2 tolls for one specific job but you will always need them. not especially expensive in ether case.. probably 25 for the pair if you shop about..
  8. looxor-lad
    pug looxor 02
    yeah cheers minor. might just pop the engine into the local shop as hes pretty good and cheap especially now most of the labour of taking the engine out is done
