Gear ups
Discussion in 'Scooter Tuning' started by stephenfozzy, Sep 13, 2007.
  1. stephenfozzy
    stephenfozzy Member
    What performance difference is there between a primary gear up and a secondary gear up?
  2. MiNoR cOnFuSiOn
    none, you can just make different combinations of gears witrh the different sets for the perfect ratio.. work out what kind of top speed increase you want. more top speed means less accell tho
  3. stephenfozzy
    stephenfozzy Member
    cheers i thought that was the case but never been clear, how easy is it to fit a gear up thats already pressed? is it just take one out put the other in ?
  4. jj180
    jj180 Active Member
    Mrt 183/Vespa 300
    yes once its been pressed you jst replace the old with the new obviously replacing all the washers correctly and as they were before
  5. MiNoR cOnFuSiOn
    if its a piggy motor you need silicone to re-seal the plate to the engine as theres no gasget.. less is more with silicone as always
  6. stephenfozzy
    stephenfozzy Member
    ok cheers m8 i fink ill save sum muni nd order a few bits
