Gear up kits!!! Advice
Discussion in 'General Tuning' started by Jimmy yates, Jun 10, 2012.
  1. Jimmy yates
    Jimmy yates Member
    I was thinking about getting the stage6 primary gearing, Does it make a lot of diffrence on the streetrace 70's? Thanks!
  2. Kurt Galyer
    Kurt Galyer Member
    hi mate i have zip sp with a pm tuning 70 kit and a stage 6 primary gear up kit with other tuning bits stops them over reving and gives youu more speed top end worth the buy.
  3. bulliporker
    bulliporker Member
    what sort of top speed do you get now kurt
  4. Kurt Galyer
    Kurt Galyer Member
    I have been told that it has sat behind a car at 74mph but i have had my 70 kit ported and polished but should sit at 65-70 i reckon mate
  5. Mr Bizzle
    Mr Bizzle Active Member
    04 Aerox 70 stage 6
    Pedparts have said it and I agree that you don't need a gear up kit with a streetrace due to the broad powerband they produce. I hav'nt got one and the bike is plenty fast and a beast off the mark. unless you intend spending all day at 65mph and want higher gearing for cruising , don't bother. When i go out with my mates on their derestricted 50's my speed is governed by them . I just hang about at the tail taking it easy while they are thrashing their bikes ahead of me. A quick twist of the throttle sees me past them all in seconds if needed.
  6. Kurt Galyer
    Kurt Galyer Member
    Well as i travel a fair distance to work i put one on for sitting at a comfortable speed with out the engine reving its tits of as it lowers the rev range and takes some stress off the crank and mine is quicker off the line to a friends zip sp with just a 70 kit so i think its worth doing!!
  7. Mr Bizzle
    04 Aerox 70 stage 6
    i go along with what Kurt is saying especially with a pm tuning kit which has a narrow powerband. its just that the streetrace kit has such a wide powerband unless you want to travel at high speeds for long distances then a gear up kit is not necessary. But you pay your money you take your choice.
  8. jiangshiyi1961
    jiangshiyi1961 New Member
    I hav'nt got one and the bike is plenty fast and a beast off the mark. unless you intend spending all day at 65mph and want higher gearing for cruising , don't bother. When i go out with my mates on their derestricted 50's my speed is governed by them . [​IMG]
