Gear Up help
Discussion in 'General Tuning' started by astro77, Oct 22, 2012.
  1. astro77
    astro77 Active Member
    Hi guys just fitted malossi 70 sport to my gilly dna and looking for a gear up, 20% or less. Only one I found is this
    http://www.pedparts.co.uk/product/956/malossi-primary-gear-kit-gilera-dna-50
    14/48 teeth, will my kit pull this I'm guessing the ratios will be different than normal scoots because of the large wheels the dna has. If anyone has any experience with the dna or can link me to a suitable gear up for the malossi sport would be greatly appreciated :)
  2. gilly_runner
    gilly_runner Member
    Gilera runner
    Your best bet it to phone them and ask im sure they will be able to tell you
  3. andy-pp
    andy-pp Member
    yes, that kit is fine for malossi sport-
    the dna gearbox is lower geared than the other piaggio engines because of the larger back wheel (which gives it the same gearing overall)
    14:48 is almost 3.5:1 which is quite a bit lower geared than a normal piaggio gearup kit would be -so again this is to compensate for the larger wheel :)
  4. Callum Coles
    Callum Coles 2003 Piaggio Zip Sp
    2003 Piaggio zip sp
    yeah it will fit fine my friend has it in his you need it if your going to have a 70s really lol
  5. Callum Coles
    2003 Piaggio zip sp
  6. astro77
    well I've been running without a gear up with the 70s and it's fine mate, most people don't bother fitting gear ups on sport 70s, I knew it would fit I just wanted to know the ratio of that gear up I linked, which Andy from pedparts answered for me, as I don't want to loose my acceleration as I'm not to bothered about Top speed, and I've still gained 8mph and it doesn't over rev:)
  7. Callum Coles
    2003 Piaggio zip sp
    true its only worth getting one on zips because of the small wheels as the gearing runs out at 58mph on there even a 50cc can get to that
  8. astro77
    yes mate totally agree
  9. Mr Bizzle
    Mr Bizzle Active Member
    04 Aerox 70 stage 6
    A gear up kit should not affect the acceleration as this is taken care of by the variator, just make sure that you have a good variator and you will benefit inboth top end from the gear up kit and acceleration from the variator.
  10. astro77
    ah ok, which is the best variator the malossi multivar or the polini (not the naff one in the high speed kit) I run a polini belt at the moment
  11. Mr Bizzle
    04 Aerox 70 stage 6
    I don't know which one is best for your bike, but both have a good rep.
