Gear Ratio's
Discussion in 'Scooter Tuning' started by CrazyCrisUk, Feb 7, 2008.
  1. CrazyCrisUk
    CrazyCrisUk New Member
    Ok, I'm getting confused with all the ratio's and what that actually translate to in terms of performance.
    Does a smaller ratio mean the wheel turns faster, but with less torque. And a bigger ratio turns slower with more torque?
    So for your primary gear would you want a smaller ratio, and with the secondary a bigger ratio. Or is it bad to have a tiny front gear and a massive back gear. I'm kinda confused...
  2. S-c-o-t-t-y
    S-c-o-t-t-y New Member
    I am a tard
  3. CrazyCrisUk
    Cheers, that helps but......
    I still don't understand the difference between the primary gear and the secondary gear as you see them both for sale. Am I just being a ditz and the primary gear is slotted into the secondary gear making 1 working gear???
  4. MiNoR cOnFuSiOn
    right.. theres 4 gears in a box. one comes from the imput shaft where the clutch sits. this gear connects to a gear in the centre shaft (ley shaft) this is the primary gears.. the ley shaft is made up of 2 gears on one fixed shaft. the second gear on the ley shaft connects to a gear on the output shaft that the wheel sits on.. this is the secondary gearset.
    a ratio is worked out via the difference in teeth. so if one shaft is a 10 tooth and the other is a 40 tooth its a 4:1 ratio... this means for every 4 turns of the imput shaft there is one turn on the output shaft.. the lower a gear ratio (say 3:1) the more acceleration but less top end you will have.. the closer to 1:1 you get means less reduction in gears wich = more speed
    does that make sence?
  5. midge
    midge Member
    what gear set would be good for a standard 50cc (with an exhaust) to make it into a wheelie machine? someone said to use the gears from the ac engine init? but why would these be diffrent?
  6. kyle1b1
    :rofl:
  7. MiNoR cOnFuSiOn
    no 50 is a wheely machine.. pipe 70 kit and a carb... oh and some stiff ass clutch springs
