Hi, im having trouble finding where to put my new gear oil in. I went looking for it, thought id found it but turned out it was the drain plug. (it was on the side of the engine case not underneath ). So now i have no gear oil in there and cant find where to put the new stuff in. Here my whole engine casing, Heres the right hand side where my drain plug was, (just out of sight under where it says oil) This is a platic holow tube going in to the engine but that leads no where else. Its not attacted to anything else anywhere This photo is of a tube thats full of a clear liquid and got some murky white bits in it to. It leads out from the right of my air filter. Any idea what it is or if it needs draining? Sorry if these questions are a bit stupid but i need a hand and i dont understand. Thanks guys
the murky tube is the drain from your filter, clean it out it just collects the crap. as for the oil fill, it should be somwhere above the drain plug, usually a white plastic thing. if not the bigger rubber tube is a breather for the gearbox, at a push you could fill it through there.
