gear box
Discussion in 'The Workshop' started by moansss, Jul 27, 2009.
  1. moansss
    moansss Member
    well my baring in my gear box cover was gone and had a hole in and someone decided to chemical metal it back together :confused:hock:
    i have a spare set of gears but they are from a rolling nut engine.
    is there anything i can do with that to fix my bike ???
    like just change the covers over ?
    thanks
  2. MiNoR cOnFuSiOn
    nope..... there different.
    chemical metal on the outer face so not actually inthe bearing, just in the cover material itself? thats what chemical metal is for m8. if it worked whats the problem?
  3. moansss
    moansss Member
    there was no baring in there.
  4. MiNoR cOnFuSiOn
    new shape dont hve a bearing if its the back of the output shaft... dont compair it to an old shape. the berings are all diff... get a new shape gear cover and look at it...
  5. moansss
    moansss Member
    are gears from a disk engine the same as gears from a drum engine ??
  6. MiNoR cOnFuSiOn
    depends ont he egnine shape... but yes aslong as they use the same tranny cover its the same engine bar the brake...
  7. Stig
    Stig Well-Known Member
    EXUP1000
    sorry for being a bit thick and hijacking your post.....
    but whats a rolling nut enjin :confused:cratch: . I keep reading about them in posts. Is there any advantage to this type of engine compared to others?
  8. PrettyDodgyDave
    PrettyDodgyDave Member
    Runner 180
    the engine with a clutch nut on outside
    to my belief the benefit is that this bearing is alot easier changed than the one in the older style gearboxes ??
  9. MiNoR cOnFuSiOn
    yep, the imput shaft on the rolling nut engine is better desighned and lasts alot longer (again the old shape is a bearing eater and a pain to fix)
  10. Stig
    EXUP1000
    :thumbsup: cheers
