Well I return, with yet another problem... I think my exhaust is blowing at the part where it connects to the engine cause when I hit bumps I think the exhaust comes loose a tad and I lose power and it makes a popping sound like... P p p p p p p p p p then on smooth... It works like a badass. Any clue if im right cause im stupid when it comes to mechanical issues lol... Ty will a new gasket do trick?
does it sound lie the exhaust is blowing? does it become very loud when you have this problem? if so a new exhaust gasket should cure it. it could be a loose connection with some electrics, ht lead or spark plug cap or maybe just some of the loom rubbing on the frame when you go over a bump ?
Have you checked your air box is attached properly ? My speedfight use to do it because the airbox came loose. Also on another note. Please title your topics correctly.
Well the issue is guys, Definately a leak where the gasket goes. However. Im absolutely flat broke till the 16th is there any other way i can seal it temporary. Till i get paid and i can just buy a new exhaust and gaskets?
