http://img708.imageshack.us/img708/851/dsc00222zi.jpg[/IMG http://img824.imageshack.us/img824/1026/dsc00221rt.jpg http://img16.imageshack.us/img16/5203/dsc00220tk.jpg http://img689.imageshack.us/img689/376/dsc00219sn.jpg [IMG]http://img848.imageshack.us/img848/3040/dsc00218fm.jpg pictures talk for them selfs most parts are piaggio removed from 07 aprilia sr or typhoon , i also have a gilera dna , forks , front wheel, front brake lever , have few throttle cables . i also have a lc dna/runner 50 engine all cleaned and primered has brand new crank bearings and blocked water pump the engine has no crank variator , belts clutch... all it has is malossi mhr bore with piston and malossi straight intake , also have a few dellorto 17.5 carbs and standard aprilia bore with piston etc.. for prices text on : 07715583470 , im based in west london , near heatrow airport ( hayes ) but i can put things up on ebay so you can buy them
i think that i would check it online , i want 60 for that as its been used for not a long time + de restricted , there is a new coat of heat resistance lacquer so it wount get rusty
how about 25 and i throw the throttle cable in as i think you will need that ? and yh it fits any bike really
gilera runner /dna 50 cases lc ,its all in primer so you can spray it what ever color you want , water pump blocked good condition no cracks etc, it has a brand new skf crank bearings installed also comes with a pair of new seals , malossi mhr 70cc bore with piston and rings only bit is wrong with it is that it has a little scratch inside which can be polished , also comes with stage 6 straight intake hub with disk(not in picture) and all gearbox which was all striped and cleaned inseide could do with a good porting flowing and polishing , kickstart all there , sale dosent include no crank or transmission parts , the carb in the picture will be a present to any one who buys the engine offers welcome
im after a gillera runner parts so if you have some we can make a deal or i would swap something for aerox cases with gearbox
standart aprilia's cylinder , airfilter and one variator sold, rest is still there going for very low prices!!
Please remove the frame with no numbers/ log book from sale or thread will be locked and deleted for sale of probable stolen parts. Thank-you.
ok so the malossi bore and piston, aprilia's airbox, both dellorto 17.5 carbs , aprilia plate holder, all variators and rollers torque drive contra spring and clutch and the bent leovice is SOLD
