Fully synthetic oil
Discussion in 'Scooter Tuning' started by PJ, Feb 12, 2008.
  1. PJ
    PJ New Member
    ive just bought a malossi 70 kit & carb, just waiting for it to be fitted, does the 2t tank need to be drained & the oil replaced with fully synthetic oil ? Thanks chaps
  2. monty9120
    monty9120 Active Member
    Vespa gts300
    what are you using now?
    its best to use semi on run in anyway as it helps bed the rings in better.
    if its mineral oil then it will need to be drained as fully mixed with mineral may froth up and cause a lock in the oil line
  3. PJ
    PJ New Member
    im using a mineral oil at the min, will i have to empty the oil pump & all pipes before i refill with fully synthetic ?
  4. monty9120
    Vespa gts300
    put some semi in next then have a few bottles of that through and then use fully
  5. SR-STEF
    SR-STEF New Member
    use fully synth.
    putoline ttx
  6. alexsr70
    alexsr70 New Member
    after its run in, fully synth isnt a good oil to run in with
  7. Jamie
    full synth puts a protective layer on the rings which prolongs the running in period....
    jsut use semi til its run in
  8. TGB-69cc
    TGB-69cc New Member
    183 Runner
    i used semi-synthetic oil for about 250miles for running in..
    now i run my morini 70cc on fully-synthetic..
    worked mint untill i baught some cheep SHIT £2 oil from a p4cky garage rode 2minuites down the road an it decided 2 seise up on me..
    that was me 70cc kit gone.. scored the barrel.. :wtf:
  9. JohnSpeedy
    JohnSpeedy New Member
    Ouch ! :wtf:
  10. Mehmet
    Mehmet Active Member
    AUDI A3
    OMG shit i have got to stop using mine then ..... :msn1:
    Im gona drain it out now lool
  11. MiNoR cOnFuSiOn
    aslong as its 2 stroke oil for autolube systems it is fine, probably chainsaw oil youve used or somthing similar.
  12. monty9120
    Vespa gts300
    yer the oil proberly reacted with the fully synthetic factory made oil and causes a lock, seizing it. surely you could have afforded some better oil instead of putting a kit on your bike
    whats more important a 50 that runs well or a 70 that doesnt run at all :pimp:
  13. J-Nitro
    J-Nitro Active Member
    yeh I wouldnt bother with nothing more than semi to be honest whilst running a sports setup, not worth it in my opinion, semi is more than enough protection for what you need.
    use mineral oil for the first 300 - 500 miles then just add semi grdually into the tank, I never worried about mixing different types, never did my 70 any harm
    I would advise though just for good peace of mind add a dash of 2 stroke to the first tank of petrol (about a capful)
    the main concern you what to be thinking about whilst running a 70 kit in is properly fitting, make sure everything is properly fitted and lubed up you cant go far wrong then...
