fuel problem
Discussion in 'Scooter Tuning' started by cdm, Nov 24, 2012.
  1. cdm
    cdm New Member
    Hi, first post, my son has a 2010 50cc aerox, the problem is I can not get fuel threw system unless I take off air filter and hold my hand over the carb air intake until it fills the the bowl, then I have to replace the air filter, then it will start with no problems for most of the day, but the next day when I try to start it, same problem, no fuel getting threw again,
    Bike has had a top end rebuild,compression good,and new spark plug,bike runs fine.
    I hope i am in the right section,sorry if im not
    PLEASE HELP
  2. MARSH
    Try giving the carb a good clean and check the vacuum tap on the petrol tank, any air leaks on pipework?
    Todi-Corsa likes this.
  3. TGB-Tuning
    TGB-Tuning Gladiator 125cc
    Gladiator 125cc
    Have you replaced your fuel filter?
  4. Rick Simon
    Rick Simon New Member
    2 stroke only
    Tried checking the vacuum hose between your carb and fuel pump? It might be a bad quality one. Also check your intake manifold, they commonly crack on newer aeroxes (2007-)
