Hi i have just brought a 2014 speedfight 3 and previous owner said that i needed to add 2 stroke oil to tank with petrol anyone tell me the mix ratio please also wondered why no separate tank also anyone no were i can get any info on this bike manual download ect cheers
yes see a hole there and when i asked they said wasn't a tank had to mix in fuel tank maybe faulty ? anyway of checking if it works? sorry totally newbie to bikes and scooters
They took it off I guess.... You just need to mix oil in with the petrol. About 3 percent oil is probably right. So 3ml oil per 100ml petrol. Or 30ml per liter.
You will need to buy one, and probably a pump and oil pipes etc. I wouldn't recommend it if you didn't know where to look for it....
They probably premix because the oil pump packed up in the past, or because those bikes are known for drinking oil faster than petrol. You could check to see if the pump is working or not by attaching a piece of clear tubing to the feed intake of the pump and see if it gets sucked down and fed out through the other pipes, but do it after you have premixed the fuel first, just in case.
so if i get oil tank and pump i should be sorted see this seems to have cap and oil sensor with it https://www.ebay.co.uk/itm/Peugeot-...173304?hash=item340a018d78:g:WVwAAOSwO7haAXDp
Curious as to why it has a fuel filter in the line............but check the pump operation first and don't get carried away with buying stuff before you know what you actually need
Thats a oil filter looks like fuel filter diffrent part number so will get a oil tank then test the pump
I'd be testing the pump first for a simple reason.........if it doesn't work then you order a new pump plus the tank at the same time and they should end up being delivered together instead of buying a tank, testing the pump, tank gets delivered, pumps knackered, buy a pump, wait for delivery....... Dude......slow your impulses down........
