Well i got my aerox back from my dealer and drove it back from salisbury to fareham, all was fine then i woke up in the morning to find lil drops of fuel or oil maybe both below my ped, it still runs as it did just has has a leak and the fuel goes down very quick it went to the garage because it had muck in the carb so they cleaned it out please help of were the leak could be
why didnt you just clean your own carb? and check that there is not dirt or stones stopping the float chamber from sealing properly if all is good check the needle thing inside of the float chamber then check the fuel pipe for splits or cracks
It's all about being methodical, it isn't hard to disect a carb and put it back together so long as you take the time to remember what you've done and know what you want to do in the first place. I'd check that your fuel hose is tight with a clip on it and that the float chamber bowl isn't being bled. I suggest researching it anyway as obviously some bellend you paid couldn't fix it right so you might as well save some money and do it yourself
if your gonna take something apart and are worried about how it goes back together or your likely to forget, take photos in stages on your phone
or even easy parts nl diagrams and numbered baggys, helps if youve got alot of empty baggys lying around and a wrecked memory LOL unk:
ohhhhhh yeh that sounds liek a good idea i found the problem and i dont no what its called but the rubber bit wer it enters the engine, the hose clamp on that was broken off but just hanging on there so i replaced it with anohter hose clamp
