front twin disc mod
Discussion in 'The Workshop' started by tengai, Jan 28, 2009.
  1. tengai
    tengai New Member
    heard that it had been tried or done anyone know of any or information
  2. baz172
    baz172 Member
    adly predators had twin disk as standard might be able to utilise the wheel off one of those doubt the forks are up to much though ?
  3. tengai
    tengai New Member
    adly predator front end
    thanks for that just doing a bit of research on that one now i think theyve got 12 inch wheels maybe work with a bit of tinkering
  4. typh70
    typh70 New Member
    would be good but wouldnt you have to use the forks too for the caliper mounts ?
  5. tengai
    tengai New Member
    twin disc/suspension
    thats what im trying to find out i know predator front forks units are s***e (grease filled,so im led to understand)but could be fettled possibly
  6. wobbly_trials
    Its a good idea but i'm not sure it's necessary, i can lock the front end on a scooter with 1 finger anyway, how much better do your brakes need to be?
    and if they get much better then your'e going to start bending the front end (assuming you are using extremely sticky tyres.
  7. tengai
    tengai New Member
    more of an obsession for cosmetic purposes really cost will probably outweigh viability!
  8. GRIMEZ
    GRIMEZ New Member
    i've seen one of the euro tuners with a double disk not sure on what bike tho
  9. wobbly_trials
    good answer. It depends on your budget but have you looked into getting your own wheels manufactured from scratch? or maybe using polished spoked wheels, that way you could use the hub from an old honda or something. not quite sure how the back will work though.
  10. tengai
    tengai New Member
    having own wheels manufactured good idea still need to solve bottem leg problem for right hand caliper though will mull that over know anywhere that would make front wheel ?
  11. wobbly_trials
    Its an expensive process and i wouldn't know whare to start looking for someone to do it.
    for the other leg, you could have lugs welded on or in some cases you can put a left leg on the right hand side.
  12. Jefr0-180
    Jefr0-180 Active Member
    I've thought of this for a runner, may have a look at doing it when I get on, but as Wobbly says, you can lock the front with one finger, but then there is looks. Would look good.
  13. nrgandy
    nrgandy New Member
    ive designed this kinda before for a nrg just anothe plate made for the other side of the wheel bolted on then welded and just use another brake said fork foot its possible i just cba doing it tbh
  14. tengai
    tengai New Member
    thinking about upside down front legs and make bottem to suit fitment of extra caliper anyone know of scoot with upside down suspension legs? an idea has partially formed in my brain!
  15. nrgandy
    nrgandy New Member
    only ones i can think that would be easy is piaggio one if you go ahead with this sell me your forks plz :D
  16. tengai
    tengai New Member
    would they be the nrg front forks some on e-bay form an 04 dont know about fitment though anyone have any measeurements for nrg ie front wheel size leg length yoke width stem length/width or know of fitment to any other scoot please.
  17. wobbly_trials
    Personally i wouldn't go with piaggio forks as they tend to be a bit chocolatey. I would go with something like X8R or possibly katana forks.
    if you're going to this kind of level though, re-manufacturing forks to go upside down may be an easier alternative. although it would require a lot of measurements, re-calculation and swearing.
  18. tengai
    tengai New Member
    need to see them in the flesh so i can see what im playing with shall have a ride around today see what i can find
  19. nrgandy
    nrgandy New Member
    true piggy ones aint the best tbh and ill have to find my lil plans that were verry rough but the idea is there lol
