Found THIS when i took exhaust off
Discussion in 'The Workshop' started by zip50sp, Dec 18, 2009.
  1. zip50sp
    zip50sp New Member
  2. bertie
    bertie Active Member
    '93 Skipper LX125
    That looks like part of the catalist converter which is found inside a little plastic box (like a mini airbox) with a rubber pipe connected to the box. Normally found above the exhaust so you've knocked it off, or it was already loose and fell off.
    Ive read your other posts, I think you said your gonna de-cat the engine anyways for the new pipe you got. So yea its de-catted for sure now you might aswell remove the little box it came from and the rest of the cat-converter pipes, then either upjet slightly to suit or make a blockoff in the airbox where the cat connects to.
  3. zip50sp
    zip50sp New Member
    i was gonna upjet to 62 im on a 60 and block the airbox... shall i only do one?
