Ford Ranger Crew Cab Airbag Light
Discussion in 'Car chat' started by Stevep, Nov 20, 2014.
  1. Stevep
    Anybody able to tell me what this little problem code is:
    Ford Ranger Double Cab, 2.5TD, Manual, 4x4
    The airbag light is flashing twice slowly, then pauses for a long long time, then repeats.
    Slow Flash, Slow Flash, long pause, Slow Flash, Slow Flash.
    Thats it, Just repeats all the time.
    Checked all the forums, can find stuff about seat belt pre-tensioners and airbag modules but the codes given are not what I have going on.
    Checked under the seats and I have no plugs going to the seat belt anchors. Unplugged the drivers and passenger side airbags seperately and that gives a completely different set of flashing codes, so I can rule those out as the cause.
    Plugged my diagnostic in and it came up with nothing.
    Any help would be appreciated.
  2. scootzmadness
    what year is it?
    I know with fords itll have nothing to do with the seatbelts. usually if the diagnostic comes up with nothing its fine just a case of paying somebody with the ford computer/disc £25 to come out and switch it off (dealer will charge £100+). its probably just the ECU being funny but wont cause any issues with the actual deployment of the airbags should a accident happen. but just to be sure its worth checking the connections for the sensors on the slam panel? I think that's where they are and checking theyre ok.
    which diagnostic plug in did you use for it? some might show codes up, some might not.
  3. scubabiker
    its could be like my camaro, where its an OBD2 plug but OBD1 software? just take the bulb out, problem solved....
  4. Stevep
    Only two crash sensors on this, both on the front chassis rails below the rad mountings. It's got the same obd socket as the Mazda B2500. Tried both OBD1 & 2 with no joy:(
    It's gonna have to go to the garage in the near future I suppose. £35 they charge. MOT in January so it needs to be sorted by then, plus I've REALLY got to do the timing belt and tensioners on this.
    Been saying it for 3 years now............o_O
  5. scubabiker
    take the bulb out, its FREE.... FREEEEEEEEE!!!!! problem solved!
  6. Stevep
    Yes, but I'll know it's still there!!!!!!
    Plus I haven't checked to see if it's a bulb or an LED
  7. Stevep
    seems i might have a faulty restraints control module, located under the centre console behind the gear sticks.
    Hmmmmm....................
  8. scootzmadness
    expensive job done in a garage IF that is the problem. a do it yourself job however ;)
  9. Stevep
    Was the correct diagnosis. Took a flyer and replaced the restraints control module, no more flashing airbag light. £40 off Fleabay, found a place in coventry that had one, went over, plugged it in, hey presto, cured.
    Happy bunny again
    scootzmadness likes this.
  10. scootzmadness
    Glad that's sorted then?
  11. Stevep
    Yup, booked in for mot on monday morning. Doesn't run out til next friday but gives me time if anything does need doing.
