Flat spot in rev range - PLEASE HELP!
Discussion in 'The Workshop' started by UK247, Dec 20, 2009.
  1. UK247
    UK247 New Member
    I have a 2004 Suzuki AY50 Kantana-R LC Fuel Injection in VGC with just under 11,000 miles on the clock, 1 previous owner from new. Just been MOT'd a few weeks ago, passed no problem atall.
    It pulls away nicely BUT when it reaches max revs it bogs aggresively when on full throttle. To get back up to full revs I have to let the throttle off completely and build up the revs again to get more power.
    I have no idea whats wrong with it. It starts first time hot or cold, idles fine its just when riding it develops a flat spot and can't rev to max rpms. Anyone have any idea what could be wrong? Been involved in MX all my life, but I am a total noob when it comes to peds - PLEASE HELP!
  2. m1ck_t
    m1ck_t Moderator Staff Member
    alot of shit
    rollers/belt i think
    when last serviced?
  3. capri dave
    capri dave Active Member
    hopefully this is a transmission related problem, as your bike is fuel injected any fuel related problems will probably need specialist attention...
    you dont mention a sports pipe being fitted, so i'll presume the scooter is stock :glare:
    the 1st thing that comes to mind is flatted or too heavy rollers...if the rollers check out ok
    Has the bike recently had a new kevlar belt, as these often run a bit boggy for about 20 or 30 miles while they bed in...
  4. UK247
    UK247 New Member
    The service record shows it was serviced twice. First serviced in 04' at 3000 miles, last serviced by a dealer in 05' at 5500 miles. It has been declared SORN for 1 year, not been started/ridden. I knew the previous owner and he claimed he had done all his own servicing from there after.
  5. UK247
    UK247 New Member
    It has a Technigas full exhaust. Everything else is stock as far as I'm aware.
    I'm thinking about purchasing a Polini Variator kit and Polini Kevlar belt is this worth it?
    What tools will I need to fit these parts?
    Thanks for your help guys.
  6. capri dave
    if its got a sports pipe, it will indeed need lighter rollers and tighter clutch springs ;)
