fitting waterpump repair kit...
Discussion in 'The Workshop' started by oliwest, Aug 3, 2011.
  1. oliwest
    oliwest Member
    aerox road legal pit
    hi , ive just bought a waterpump repair kit for my aerox (the rubber gasket or seal around the edge has water dripping out of it) do i just take the hoses off undo the pump0 cover am slide it off then fit the new gasket an its done?
    sorry first moped an im not good with engines lol :cheers: :cheers:
  2. jet
    jet New Member
    you have to take the flywheel cover off aswell, so you can get to the cog once youve done that thers a pin that holds the cog on to the shaft take that out, pull off the cog and slide the pump out, just make sure you look closely at how it all goes together when you take it apart makes it easier to put it back together. its not to difficult anyway.
  3. oliwest
    oliwest Member
    cheers mate but if i need to do just the seat thats right behind the cover do i still need to do that? cheers :)
  4. jet
    jet New Member
    yeah you need to take the pump out because the seals behind it, think thers a circlip on the cog too? youve probably done it now anyway. aerox engines are pretty simple if you just take your time and see how it all comes apart.
  5. oliwest
    oliwest Member
    ohhh i thought the bit leaking(the rubber seal or what ever it is) was the pump lol
    got the kit an it has bearings a little fan type thing an a seal never new it was going to be tiny lol
    hmm recon itll be ok for a newbie to do or should i pay the 40 quid an get the shop to do it?
  6. jet
    jet New Member
    nah pretty simple thing to do just be carefull putting the bearings in take you half an hour max
  7. oliwest
    oliwest Member
    ok cheers for all the help mate! ill have a go at it tomorrow :p so the 3 bolts that hold the little cover thing on(the thing the water hoses go in) do i take them out an slide the thing off then replace seal then if the fan things fucked replace that too?
  8. jet
    jet New Member
    yeah undo them and then the 3 that hold the fly wheel cover on
  9. oliwest
    oliwest Member
    cheers mate!
