fitting tires
Discussion in 'General Scooter Discussion' started by jmcleeds, Jan 28, 2008.
  1. jmcleeds
    jmcleeds Member
    Managed to fit 2 tires 1 old and a brand new one, what a pain in arse. took me 30 mins and had put both on wrong way according to tread pattern managed it in end.... any one else tryed this?
  2. JakeSP
    JakeSP New Member
    I always do my own tyres. I do it using a tyre changing machine though, Done and dusted in about 5 mins!
    (And i dont to put up with having the fear of any monkey chewing up my rims!)
  3. jmcleeds
    jmcleeds Member
    lol i didnt use any tools, just a rubber hand from some pliers. had to put lots of industrial and cleaner on it to make it slippy
  4. wobbly_trials
    if they are fitted the wrong way then they are illegal.
  5. Mehmet
    Mehmet Active Member
    AUDI A3
    Yeah your right mate but unless the tyres arent The wrong way they should be Then no one is going to know there for the Police wont know will they?
  6. CrazyCrisUk
    CrazyCrisUk New Member
    The big arrow facing the wrong way might be a give away...
    Anyway their made to work going a certain way, I'm no expert but I'm sure you'll get less grip using them the wrong way round. Especially in the wet as the groves chuck the water to the side, back to front they'd scoop the water into the middle of the tyre.
  7. Mehmet
    AUDI A3
    Yeah your right. Wouldnt want to end up doing that i would jus take it to the tyre shop let them Fit it :p . You only pay like £10 Extra to get them fitted anyway.
  8. sc_bk
    sc_bk New Member
    I've done a few by hand, not easy but you get there in the end. Pretty fiddly when it's tubed tyres aswell!
    As Jake says easiest on a machine, it gets the rubber on and off in seconds
  9. foster
    foster New Member
    just got loads of fair liquid and your sorted :p
  10. wobbly_trials
    NO no no and NO!
    washing up liquid contains salt, salt causes alloy corrosion, give it a month and your rims will be furry.
  11. foster
    foster New Member
    lol too late i did that to mine in july....lol
  12. Mehmet
    AUDI A3
    LOL. any effects to the wheel yet ???
  13. foster
    foster New Member
    not that i can see, just cleaned them yesterday. not saying that ur wrong thou wobbly :p
  14. Mehmet
    AUDI A3
    LOL he could be right maybe it depends on the alloy or if and when you do change the wheel and you dont clean off the fairy then maybe it could damabe the wheel ?
  15. wobbly_trials
    when you take the tyre off it'll probably be crusty and furry along the tyre bead.
  16. sc_bk
    sc_bk New Member
    I've used fairy liquid before, once the tyre's slipped on wash everything well before inflating the tyre
  17. tomo9992
    tomo9992 Member
    RS125
    so what slipperly luqid cud be used then? any house hold items so i dont have to go buyin anythin lol
  18. SMF_12
    SMF_12 New Member
  19. J-Nitro
    J-Nitro Active Member
  20. monty9120
    monty9120 Active Member
    Vespa gts300
    wd40 i all you need
