Fitting problem with a malossi variator to a typhoon 125
Discussion in 'The Workshop' started by jimmytyph, Jul 20, 2009.
  1. jimmytyph
    jimmytyph New Member
    Why doesn’t a malossi variator fit properly to a typhoon 125. The malossi variator comes out too far when put on.
  2. breamy
    breamy New Member
    Typh 172
    u mean it forces the pulley out ? if so all the fins need lathing off so its a flat face
    if u mean the variator sticks out way 2 far it all wants shimming up propper
  3. MiNoR cOnFuSiOn
    WHAT???? if the front pulley is sticking out the belt is not gonna run straight... it HAS to stay where it is..
    you have not got the correct ammount of spacers in the rear of the variator.. that or its NOT a typhoon variator.
  4. TyphoonLagoon
    TyphoonLagoon New Member
    do u mean when u fit it with the thick washer behind it the crank splines go thinner and the varo backing plate teeth dont fit onto the crank? its because the crank is a standard crank, just tighten everything up and it will be fine :) if thats what u mean anyways
  5. m1ck_t
    m1ck_t Moderator Staff Member
    alot of shit
    all of mine used to slide on/off freely. just pull and push back on with your hands
  6. jimmytyph
    I mean the variator comes out too far compared when I put the standard variator on. I will change the washer behind the variator and see how it goes. Btw its malossi variator from my friends gilera runner sp125.
  7. Bradley_18
    Bradley_18 Member
    runner 172
    Did he give you the bar bit that that goes threw vari aswell or are u trying to use the standard one? That would explain ur prob as the one for standard vari is longer
