fitting a polini sport 70 on an aerox.
Discussion in 'The Workshop' started by Aerox-lad, Sep 20, 2009.
  1. Aerox-lad
    Aerox-lad New Member
    hi all. was just wandering if you can fit a new barrel to an aerox without taking the engine out cant really be bothered to take out the engine if i dont have to? cheers
  2. BAMFORD#139
    BAMFORD#139 New Member
    APRILIA SR50 FACTORY
    dont be lazy
    yeah just take it out it will be easier + dont no if you can change it without taking the engine out
  3. nrgandy
    nrgandy New Member
    you could be able to but you will need to take panels off i find its alot easyer to have a engine on a workbench tho
  4. mgyz3@hotmail.com
    mgyz3@hotmail.com New Member
    Gilly 172
    You can but if you still have an oil bottle then that will be in the way but u can still get it on its just a bitch
  5. matthewl
    matthewl New Member
    not trying to be a twat right but i find it is actually easier to do it with the engine in because you dont have to piss on pulling it out and putting it back taking all the hoses and disconnecting the electrics
    just take your bellypan off and get on your knees will save so much time.
  6. Aerox-lad
    well i think i'm going to give it a go with the engine still in. i was told by a mate who has been working on aeroxs for years that it's a good idea to take off the rear shock and this will lower the angle on the engine to make it easier
  7. steve w
    steve w Member
    03 aerox
    i must agree with the above its alot easyer to take the engine out . take the 2 bolts off and it just slides out 2 sec job
  8. Ricky70
    Ricky70 Member
    70cc derbi gp1
    would make the job alot easer if you pull the engine out.then you know everthings going to be on tight and propley if you there leaning over panels and trying to ram you spaners in at angles somthing could go wrong.for the sake of an extra 10 min work you may as well.
    also while its out you could give it a clean and cleck it over for any damages. :mrgreen:
