Hi folks Just got myself one of these and I'm new to scooter riding When do you think is a good time for its first service and what do they do when you take a scooter in Will they do jobs like oil changes or is that down to me Sorry for obvious questions but this is all new to me Cheers Kris
usually the bike shop will have a list of what they check. things like valves - oil - tyres and pressure , it can differ between shops but its like a pre mot check.
Things bed in after a few hundred miles so it needs checking and adjusting. If you have an owners manual it will tell you at what mileage the first service is due. It may also list the items that are checked on each service interval. The first service is important as the engine oil/filter will need changing as any particles that may be there during manufacture will need flushing out and valves etc will need checking/adjusting and a general check in case anything has come loose. If you find anything wrong or needs attention mention it when you book it in. It's also important from the warranty point of view. Just ring your dealer near the time it is due and book it in. For example if it's due at 600 miles and you do a 20 mile commute then just over 500 miles would be the time to ring which allows 5 days for the dealer to get it in. If you do less miles adjust the booking time to suit. The mileage isn't that critical as long as you book it in shortly before it's due and the dealer is aware. The first service is due at 300 kms(app 200 mls) according to this which isn't much but check with your dealer or owners manual. Your odometer will probably be in kms. http://www.fuelarc.com/images/model...ser_manual/sym-fiddle-iii-125-user-manual.pdf
300km service they will redo the oil due to break in period ( engine oil change ) , then they will go over and check the usual nuts bolts and working parts just to make sure everything all fit for purpose and is not a danger for you, the first service is always free so you should not be charged for this . then they will stamp your service book and away you go until the next service ( the next one could be a charged service so ask before you leave so you know before hand )
Thanks Been taking it out for practice rides and to wear in the engine Finding I'm getting a slight burning aroma after using the bike for an hour
