few pics of my aerox as it stands now
Discussion in 'Pictures' started by 70ccAerox, Apr 3, 2011.
  1. 70ccAerox
    70ccAerox Member
    hoping to find out if i can run the 70cc kit on standard carb for the summer?
    and also how would i go bout starting it was parked up for 8 months and the kickstart is seized?
  2. tErr0
    Look at that poor exhaust. :(
    Take the tranny cover off and have a look. Grease it up etc.
  3. 70ccAerox
    70ccAerox Member
    i know has been under a bike cover out the back for a while and the elements got at it :banghead:
    thanks will try the greasing up of the kickstart think the piston might have rust in the cylinder do?
    anyway to fix back up the exhaust aswell ill look at the bike and get full spec up later aswell
  4. Gamble
    Gamble Member
    That exhaust should come up nicely - seems like a lovely start. Get up a few more pics, spec up and what's your plans for it? :)
  5. 70ccAerox
    70ccAerox Member
    sound for the comment gamble :)
    got working on the bike lately put it into my shed and got cracking! took off the head and engine cover to find the crank was seized so oiled it up with wd40 and it got it turning over again :)! got painting the exhaust too and trying to find cheapest place to get parts now for it i need the bearing,gudeon pin and clips for my 70cc piston and i need to find out where the hoses go on stock carb?
    heres a few pics of it
    spec i no so far is yasuni exhaust,malossi mhr 70cc kit, racing crank not sure on make but has power1 wrote on the arm,malossi clutch variator,bigger belt,malossi cdi unit,and longer gear kit fitted,smoked back lights,michelon pilots back and front,high riser etc
    plans are spray the whole bike satin black.get it running with the stock carb and then once its running upgrade the carb and reeds to 23mm carb maybe :)
  6. xplicit vehicle
    xplicit vehicle Member
    PGO Big Max 50
    why does everyone go for normal ones? have u ever though about metallic?
  7. 70ccAerox
    70ccAerox Member
    im gonna go with gloss black im from ireland and there is no black aeroxs where im from :cheers:
