Exhaust Smoke Engine Off???
Discussion in 'The Workshop' started by lloydowen, Apr 5, 2012.
  1. lloydowen
    lloydowen 40MPH Sucker
    2001 Suzuki Zillion
    Hey guys, I recently fully rebuilt my engine, I replaced it with new crank bearings and seals. When I put it together everything worked fine and still does but I am experiencing a few problems for some reason...
    1) It takes a lot longer to kickstart/electric start...
    2) A lot more blue smoke comes out of the exhaust for the few couple minutes of driving even after waiting for it to warm up..
    3) When I shutdown the engine, around 30 seconds later short puffs of smoke continues to come of the exhaust..
  2. xplicit vehicle
    xplicit vehicle Member
    PGO Big Max 50
    im assuming the reason for more smoke would be that u put 2stroke oil to lube up the bearings etc. but if its continuously more then it seems for some odd reason u have more oil in ur mixture (maybe u added more on the oil pump).
    i would just think that the smoke would be just left over smoke still travelling down the exhaust?...
  3. lloydowen
    2001 Suzuki Zillion
    Cheers... I didn't use 2 stroke oil to lube the bearings. We used grease and then when the bearing was in place, removed as much as possible. No worries the symptoms seem to be disappearing over time anyway.
