Hi all, As title, I sent some parts off to powder coaters but when they have removed bearings from the exhaust mount/swing arm, I know have no idea how they go back in. There are 2 bearings (I have new ones), a seal and 2 circlips. In the larger hole on the mount there are 2 grooves, one right one the edge and one set further back, I'm assuming this is where the circlips sit. However I can't figure out if the bearings should sit on top of each other, or if there should be a spacer between them. There is a spacer which goes on the axle after the wheel but that's all I have. Does anyone know the correct way to reassemble this? Cheers
