Exhaust Leak
Discussion in 'Scooter Tuning' started by KyleH, Dec 1, 2013.
  1. KyleH
    KyleH Member
    Aerox 11 Plate
    My aerox had been dieing at WOT and spr racing said it was a vaccumm fuel line problem, doesnt suck enough fuel through. I noticed my exhaust was leaking from the gasket on the silencer, fixed that with some sealant and the bike doesnt die as much, is it the exhaust not giving the bike enough of a vaccum?
  2. Tarmacmuncher
    Tarmacmuncher Member
    09 Nrg Power
    what exhaust do you have ? if aftermarket did you rejet for it ?
  3. Stig
    Stig Well-Known Member
    EXUP1000
    could also be running too rich. I had the same issue with a ZIP 70SP...anything over 3/4 throttle and it would bog down. Backed off the mixture screw and sorted in an instant
  4. KyleH
    KyleH Member
    Aerox 11 Plate
    Ill give that a go tommorow and ill see what happens.
  5. Pig
    Pig New Member
    Also check the float in your carb. You could be running out of fuel at WOT if it's not adjusted properly.
