exhaust help!!!
Discussion in 'General Tuning' started by ashleyh363, Jan 19, 2014.
  1. ashleyh363
    ashleyh363 Member
    So ive decided to buy a cheap sports exhaust for my mbk mach g 50.. At the moment i have a 72 main jet and with a sports exhaust i know your spost to up jet as im derestrcting the exhaust. The rest of the peds standard so what main jet would i need???? Comment please :) btw the exhaust is a Tecnigas Q-Tre . Thank you.
  2. turbovetto
    turbovetto Well-Known Member
    tweaked ovetto
    Hi
    I'd start by getting a box of jets from 70 to 100 and I'd put a 90 in there. It's going to be too rich - so reduce by fives until it runs right then go up two - or down two - until you get a nice chocolate plug and good performance.
    The Mach G has the same engine as the ovetto (my scoot) and from experience I'd suggest getting the hardest clutch springs you can lay your mitts on - and reducing the rollers to about 24 g total (but this is a wild guestimate and as good as useless in terms of advice). I bet you'll end up with about 82 - 85 main jet but again - this is worthless (and possibly dangerous) advice. You have to jet big & reduce.
    Good luck -
  3. ashleyh363
    ashleyh363 Member
    Is a dry light ginger bread colour good (spark plug) ??? Thanksss:)
  4. turbovetto
    tweaked ovetto
    The most frequent analogy is 'brick' coloured. If you're 'light ginger' I'd upjet by two points - and see if performance suffers. You want to jet as rich as you can without a performance penalty.
