exhaust bracket
Discussion in 'The Workshop' started by stretch, Jun 13, 2007.
  1. stretch
    stretch New Member
    Right, my exhaust bracket snaped some how and i was wondering how to replace it
    if you look at the blue arrow you can see that the bracket some how is connected to something (lol) but i dont know what it is. i was wondering if someone could tell me what this is, what you think it is most proberly made from and also where i could get a new one of these or anyway i could fix it. the red arrow is where is has snaped
    thanks for your time
    STRETCH
  2. Ciaran
    Ciaran Active Member
    Weld it?
  3. stretch
    stretch New Member
    yeh but i have a feeling it is made from alluminium and you cant weld that
  4. wobbly_trials
    it's connected to your engine case. if the case it's self is damaged then you are best off getting it welded by an alloy welder, the bracket for the exhaust needs to be replaced too because of the broken bit, it looks as if just 1 bolt has been holding it for a while, this is why the bottom mounting has been damaged.
  5. stretch
    stretch New Member
    ye i got a new exhaust coming and im hoping that the bit that holds the exhaust comes with the exhaust. so do you think it is alluminium aswell wobbly?
  6. wobbly_trials
    the actual exhaust bracket it aluminium
    the engine casing is an alloy of some sort, not sure if the bottom hole is damaged, if it is, try a longer bolt with a nut on the back.
  7. stretch
    stretch New Member
    yeh the bottom hole is damaged but i think your idea might just work, thanks mate. ;)
