Hello, Installed Doppler Endurance, got new bearings in. The crank was spinning really freely, like a normal crankshaft should. Then I put the oil seals in. It was turning with a lot of effort needed. I forgot to lube the seals. Tried working in oil between them, helped a lot honestly. But still dragging. Will everything be ok once I start the engine up and it will get itself lubed? I don't have any more replacement parts. Thank you.
