engine swap (zip 50)
Discussion in 'The Workshop' started by dub, Jun 1, 2011.
  1. dub
    dub New Member
    hi all, i have recently got a 2001 zip 50, shame its a 50 though, was just wondering if anyone might know if there are any 2 stroke 125 engines out there that will fit in the 50 frame?
    or any engines requiring light mods to fit in?
    many thanks dub!
  2. luke_2401
    luke_2401 New Member
    Gilera runner 125-180
    Aprillia sr 125 (ac)
    Typhoon 125
    All would fit witha abit of work to the wiring loom and mounts
  3. northrider
    northrider Member
    typhoon 125 small drum is the best engine for a zip conversion because you can use the small zip wheels the main problem is the loom you need a typhoon 125 loom which are very rare
  4. Gamble
    Gamble Member
    Typhoon 125 small drum as northrider says, then you'll need the wiring loom etc and it'll all need to be wired up. It's a real ball ache and anything but a simple swap!
    Smile it puts on your face when finished though, makes it well worth it. :good:
  5. J4CK
    J4CK Member
    Piaggio NRG 172
    A Skipper 125 wiring loom is similar to a typhoon 125 wiring loom.
  6. Louie007
    Louie007 Member
    Would a vespa lx 125 engine work. At all
