engine swap lx50
Discussion in 'The Workshop' started by tinribs, Jun 4, 2007.
  1. tinribs
    tinribs New Member
    Hi guys, anyone know which 125's will fit into the vespa lx 50? i need a bit more power, got a new job and there are some big hills on the way!
    would a 2 stroke typhoon engine go in easy enough?
    thanks guys
  2. MiNoR cOnFuSiOn
    yep, typhoon engine ffits with a modded 50 mount, wheel bolts on the old shape 125 engine aswell (108mm drum) and the pipe will clear everything. you will need the typhoon wiring loom/cdi/coil also but the only hard bit will be the rear lights and the clocks. want to do one of these myself one day.
  3. tinribs
    tinribs New Member
    awesome, thanks. just have to find the bits now! guess i'll whck a ad in the wanted section!
    whats hard about the rear lights / clocks?
  4. MiNoR cOnFuSiOn
    not the same fittings for the lights (rears you can just change the plug fitting over from the 50 loom tho as the colours are the same) the clocks/switches can be a bit of a pain but im sure you can figure it with both wiring diagrams
  5. tinribs
    tinribs New Member
    im ok with vehicle electronics, i work for tracker, used to fit them but moved into research and development. handed in my notice today as starting a new job as an I.T manager closer to home.
  6. MiNoR cOnFuSiOn
    wont be a prob then m8 :D your basicly swapping frames and clocks on a typhoon, all you have to imadgen. the bike itself is irelevent ;)
  7. tinribs
    tinribs New Member
    hopefully i'll be able to wire in the clock off a lx125 so it looks the same.....
  8. MiNoR cOnFuSiOn
    thats the idea... so people dont have a clue.
    keep the whole bike the same. i ment that the entire engine/wiring from the typh is the same your just putting different clocks on it, oh and a frame :D but will look good as the typh stock pipe looks like a 50 vespa pipe anyway, wheel the same so you REALLY will supprise people. especially if you 172 the fucker
  9. tinribs
    tinribs New Member
    i will be fitting the 172 kit. at least i can use the scoot as it is whilst im sorting the engine out....
    i havnt seen too many a/c engines around, it'd be a pain fitting l/c to the lx
