Engine problems
Discussion in 'General Tuning' started by ashleyh363, Mar 30, 2016.
  1. ashleyh363
    ashleyh363 Member
    I have just got a yamaha jog RR 50, they said it keeped cutting out after a couple of miles run. I checked the coolant and there was non so I put some in and it was leaking out of the second head part of the engine, not the barrel the top head part where the spark plug goes into?
  2. SliderTom
    SliderTom Member
    Yamaha slider
    New barrel and head. Simple to do. Be methodical in the process.
    Do not tear your base gasket like me, and all will go well.
  3. ashleyh363
    ashleyh363 Member
    Yeah but a new barrle and head with a new piston will come with new gaskets anyway?
  4. SliderTom
    SliderTom Member
    Yamaha slider
    Yeah it will do, complete set for the top end.
  5. ashleyh363
    ashleyh363 Member
    So how come you said about the base gasket? Lol
  6. SliderTom
    SliderTom Member
    Yamaha slider
    I tore my one. Had to stop my build.
  7. ashleyh363
    ashleyh363 Member
    Oh. How many miles would I do with a new top end rebuild?
  8. SliderTom
    SliderTom Member
    Yamaha slider
    How long is a piece of string :)
    It depends what you plan on bolting on.
  9. ashleyh363
    ashleyh363 Member
    Sorry I mean how many miles to run it in? Lol
  10. SliderTom
    SliderTom Member
    Yamaha slider
    This varies on personal opinions and also what the manufacturer states.
    Me, i like to see 500+ miles of 30-35 mph. Steady throttle nothing too harsh, then after that. Break in to 1000 miles with usual riding, providing their are no mishaps along the way.
  11. ashleyh363
    ashleyh363 Member
    Okay I got you now :) Do u know how to set the cooling system up please?
  12. SliderTom
    SliderTom Member
    Yamaha slider
    How do you mean set it up ? As in have it filled and bled ?
  13. ashleyh363
    ashleyh363 Member
    Yes. How to fill and bled?
  14. SliderTom
    SliderTom Member
    Yamaha slider
    Im guessing your jog has a similar setup to my aerox. Besides the location of the radiator.
    But it is pretty much the same process for them all. Have your water and antifreeze, fill this up to around a 50/50 mix. Depending on our seasons, some prefer to adjust the antifreeze during winter.
    Ensure your level is between the min and max on the header tank, preferably closer to the max as you will lose some anyway through venting.
    Now, you can either remove a small pipe which goes from the cylinder head to the carburettor and allow it to vent this way, it will possibly spit and spatter for a small time
    Or remove the filler cap till the bubbles stop rising to the top, a little time consuming compared to removing the pipe from the cylinder head. But both work.
  15. ashleyh363
    ashleyh363 Member
    I think I will go with wating for the bubbles to stop.
  16. SliderTom
    SliderTom Member
    Yamaha slider
    Whatever works best.
  17. ashleyh363
    ashleyh363 Member
    Thank you so much for your help!
  18. SliderTom
    SliderTom Member
    Yamaha slider
    It isnt a problem. Hope you get your bike up and running soon.
  19. romain
    romain Member
    Yamaha tmax
    Watch out witch top end you fit some kit have a bleeder screw on top of the head
    If you don't bleed the air the bubble won't go away on it s own apart if you lift the front of the bike in some cases
    An air bubble in the circuit could end up making the engine over heat
  20. ashleyh363
    ashleyh363 Member
    This bleeding stuff is confuseing the shit outta me lol, can someone give me step by step to help me get it right on how to bleed the coolant system please!
