engine numer 2 = fucked
Discussion in 'The Workshop' started by Jamie, Nov 2, 2007.
  1. Jamie
    can anyone help me please?
    basically on full throttle my bike crakcles really loudly and looses power, like it will pop continuously really quicly then die?
    and ideas
  2. wobbly_trials
    sounds like a damaged ring on the exhaust side (assuming the crackling is from the right of the engine)
    if it's the left i'd check your transmission
    could also be a plug breaking down under extreme compression.
  3. Jamie
    cheers wobbly
    right ive had a look and i can say 2 things....my spark plug cap comes off with no force what so ever
    just slides off
    the white part of my spark plug is now black
    and yes the sound is from the right hand side
    AND there has been a weird rubbing brush kinda sound from the transmission case recently
    cheers for the help
  4. wobbly_trials
    right, whip the tranny case off, you may have a dis-intergrating belt.
    take the plug out and check the colour of the very tip.
    replace your plug cap as this wont help.
    put your finger over the plug hole and spin the engine over, it should blow your finger off the hole. if not your compression is down (more than likely a cold or heat seize).
  5. frainey
    frainey New Member
    Get that plug cap replaced as wobbly said, simple things first.
    My rox wouldnt start at all with a shitty plug cap :wtf:
  6. Jamie
    could this be the problem
    it look slike crap is getting pas the rings????
  7. chopper
    chopper New Member
    think you need new piston rings.
  8. alexsr70
    alexsr70 New Member
    have you checked for scores in the barrel?
  9. wobbly_trials
    looks like just worn rings, remove the piston, take the rings off and clean the piston up gently with some petrol and wire wool
    make sure theres no scores in the piston
    assuming it looks ok, put a new set of rings in (might be better just getting a piston and rings.
  10. MiNoR cOnFuSiOn
    id swap the piston or just find a cheapo 70 kit
  11. Jamie
    yeh thats what i was thinking mate
    just gona stick like a 2 extreme kit on and see where that takes me.
  12. jacksp
    jacksp New Member
    the end of the road? :w00t:
    joking ;)
