so guys looking for a two stroke scooter motor that i could fit into Pedros 50cc frame.Pedros engine hanger is a under hang, ie the motors mount points are underslung ( not the usual upper bracket mounting points ) im used to fitting lumps into frames not hanging them from frames. so my major question is this : where does one take measurements to get the correct numbers needed from the engine hanger and do i have any leway with the larger engines mounting points, can they be spaced or mounted outboard of the hanger and not the inside of the bracket hanger ? any ideas what two stroke would be a possible meld with the Sym Jet ?
