ENGINE DIENG ON A40 THEN STARTINGG
Discussion in 'The Workshop' started by typh70, Nov 24, 2008.
  1. typh70
    typh70 New Member
    hiya on way back from that london meet tonyt on the a40 and my bike just died, pulled up and it started straight away, done the same thing a few times but onyl seems to do it on open long straight when im travelling a bit faster. any ideas what this could be ...
  2. Ross1308
    Ross1308 Member
    I know i dont know alot but this is exact same symptoms my mates typhoon had and it turned out be his spark plug was fucked.
  3. Jamie
    if its cutting out at high revs it sounds like rings...but try spark plug first just incase
  4. MiNoR cOnFuSiOn
    check the float bowl.. sounds like its running out of fuel atn full throttle so check the bowl, check your fuel tap (replace)
  5. Samuel
    Samuel New Member
    and check the oil could have heat seized
  6. typh70
    typh70 New Member
    it cant be the rings or anything i dont think, i mean it will start up straight away and have full power only does it when going faster on straight long roads, im running a br8 in there when it should be a br9 could this be a problem ?
  7. m1ck_t
    m1ck_t Moderator Staff Member
    alot of shit
    not a major problem, just running it a bit hot, change the sparky and have a peek at the carb pal ;)
  8. alperin
    alperin Active Member
    aerox 180cc
    happen to me once and it was my oil pipe out.
  9. Jasemc
    Jasemc New Member
    Dodge HT Cable maybe?
  10. Ross1308
    Ross1308 Member
    is it the higher the number the hotter the plug not to sure, change it anyway to the correct one
  11. typh70
    typh70 New Member
    im not too sure mate...
    i cant think it would be anything else because it only does it when its proper warmed up
    you can feel it when it gets hot its loses its grunt like..
    must be the sparky
