engine Bushes
Discussion in 'Maxiscooter Tuning' started by connor, Oct 31, 2009.
  1. connor
    connor Active Member
    are sp an Vx engine bushes the same?
    and the silent block?
  2. shiny red
    shiny red New Member
  3. connor
    ok thanks, do you do ones for 4satrokes then? because i looked on your site but couldnt find them lol
  4. connor
    could some1 link me the Right ones please?
  5. monty9120
    monty9120 Active Member
    Vespa gts300
    get them from a piaggio dealer. you need a lot of bits to go with them to do the job properly so ring a dealer that knows what you mean, you need bearings tubes etc etc
  6. shiny red
  7. connor
    cheers for that xx
  8. CheekyThomas
    CheekyThomas New Member
    Ideally you need...
    1x CM067801 Inner Tube A
    1x CM067802 Inner Tube B
    4x 273773 Plastic Spacers
    4x 56127R Needle Roller Bearings
    1x 272750 Large Rubber Donut Bush
    You can change the bolts as well if money is no object, but theres no need really...
  9. monty9120
    Vespa gts300
    shiny i need to do mine eventually. i cant source a spare mount to mod one though connar have you got one
    ps cheeky i might need a whole set soon. how easy is it to do the donut bush
  10. shiny red
    easy with the right tool monty :good:
  11. monty9120
    Vespa gts300
    have you got a tool that i can buy then :mrgreen: . i need to mod a subframe like you did to a 2 stroke one to maybe make the bearings last longer. ill keep looking fella
  12. CheekyThomas
    Yeah thankfully the big bush is easy, its only plastic with a rubber centre so doesnt take much effort to fit, just make sure youve got it in the right position as it only fits in one place.
  13. connor
    monty i got a 2stroke subframe if thats what u need?
  14. monty9120
    Vespa gts300
    no 4 banger mate
  15. shiny red
    thats what you need monty ,easy to make if you have some metal lying about or they are listed on my site :good:
