electronic waterpump
Discussion in 'General Scooter Discussion' started by biglee, Mar 21, 2007.
  1. biglee
    biglee New Member
    right at the mo i have split my engine i have herd about electronic waterpumps but i was wandering what the gd things are about them and also where i mite be able to purchase one
  2. JakeSP
    JakeSP New Member
    Pretty sure they're only used for sprinting.
    Probably cos the motors would burn out after a few hours and i think they aint cheap either...
  3. biglee
    biglee New Member
    are they ment to be more reliable then you have any idea on how much??
  4. bEN
    bEN Active Member
    Ducati 848
    The only advantage i can see from having an electric water pump would be that on a hot day in traffic where your constantly stop and go it would keep the engine alot cooler, apart from that it's just another thing to go wrong, and it'll be too late by the time you realized it's gone wrong.
  5. Nrg-Sam
    Nrg-Sam Active Member
    would it even keep the engine cooler though???
    the engine still pumps coolant round at tickover doesnt it??? you need cold air hitting the rad? thats what i thought neways lol
    sam :punk:
  6. Purplepill
    Purplepill Member
    aint the pump turned by the engine though so ud have more power if the pump ran on electric rather than the crank?
  7. NrG172
    NrG172 New Member
    Typh 178
    an electric water pump is defo better than the one in the enigne it keeps it cooler although im not sure how but it is also less weight on the crank, as the crank doesnt have to spin the water pump anymore, its just the same as goin premix, so the crank is spinning faster and its more responsive :p ( i could be wrong tho )
  8. wobbly_trials
    theory is good, but what happens when the fuse goes becuse of something trivial??
    not good for on the road, and at tickover any LC or AC bike shouldn't overheat.
